Car does not start
Car does not start
well i ran into some problems with my civic...At first i thought it was just my battery but i changed that...I jump start it n let it sit for awhile then i turn it off...as soon as i try to start the car back up it wont start...need some help or advice to what is causing the problem...thanks..
Re: Car does not start
it does not crank with the new battery...i can drive the car after i jump it but as soon as i turn it off..the car will not start or crank...the lights on the dash goes out after i try to start it...i assume something is drawing power but i dont know where from
check grounds make sure the ground that goes to the battery is hooked up with a good connection, ya and check the grounds that goes from the tranny and the v.c make sure they r on good and have a good conection
i just got my alternator checked n its still good...checked the grounds and their still good too...pulled fuses and they are still good...like i said earlier battery is brand new but still the dash is still going out wen i try to start...still the motor does not crank...i can jump it to start but it does not turn back on wen i turn the motor off...need some help please!!!!
sounds like the battery is bad... you can buy a brand new batter and it be bad from the factory, maybe try and use a friend's battery and see if it works
klassesports
20
12-03-2003 10:52 PM
