soft clutch pedal
Old 05-19-2012, 11:57 AM
ozh_hawaiian's Avatar
Default soft clutch pedal
I have been having problems with a soft clutch pedal... my problem only appears if i dont drive the car for a little while; like overnight. When I get in the car in the morning, the pedal has about double the amount of free play, but after I drive for a few minutes, the pedal will go back to normal. I know there is a very small portion of the line that is rubber, so im not sure if that piece of hose is expanding enough to cause this; visually this part of the clutch hose looks fine... in the past month, I have changed both master, and slave cylinders, and have no air in the line....
Old 05-19-2012, 03:16 PM
EGyoke's Avatar
Default Re: soft clutch pedal
You probably need the bleed it again. I had the same problem and found out there was a small air bubble causing the problem. Keep trying to bleed it until you feel the correct pressure. Were all the parts new?
ducsaim
01-14-2011 12:17 AM
egonthree
24
11-17-2009 09:05 AM
SilverDC4
04-08-2005 08:07 AM
Quick Reply: soft clutch pedal
