replacing piston
replacing piston
so i cracked a ring land i think it was cause of low oil
and i looked at the bearing and theyre prob all junk since this one was
i rebuilt this engine and had the crank polished and block honed for a chrome ring. all the pistons came from the same engine and i had them reconditioned for ARP bolts. now i need a new piston. can i re use the rings if i get them off with out damaging them? think it will be ok to have napa or some where put another stock piston on this rod throw new bearings in it and go?? or can i just put one complete other rod and piston in with out arp bolts
Re: replacing piston
you should never reuse rings. you should also check the cylinder with the damaged piston for OOR and Taper. thoroughly inspect your cylinder wall for any damage. you should never cut corners, do it the right way the first time and you shouldnt have to worry. good luck
