92 Civic VX - No start
First post here.
Finally found a 92 Civic VX, nice Calf car, bought it not running. PO tinkered with it, anyway I own it now
Searched here & followed the suggested "Advanced Ignition Trouble shooting" at the Team - Integra.net with the following result
Timing belt: rockers operating as viewed thru oil fill
Engine ground: cleaned G101 ( thermostat housing)
Primary Coil Resistance: 3.3 ohm ( is this within range? is this the problem?)
write up said .6 ohm
Secondary: 11.9 ohm
ICM: supply voltage Bk/Y and gnd - 12vdc
Wht/Bl and gnd- 12vdc
Test light fait flash while cranking engine
My guess ( I hate to guess) would be the ignition coil
Suggestions?
Thanks Gents
Secondary: 11.9 ohm
Suggestions?
Thanks Gents
Re: Civic- No start
Let's start with the basics.
Bone stock VX?
Does the starter crank the engine?
Does the fuel pump prime?
Is there bright white spark at all 4 spark plugs?
Is the mechanical timing properly set?
Are the cylinder compressions similar and adequately high?
Any CEL codes?
Bone stock VX?
Any CEL codes?
Re: Civic- No start
This.... need a little more engine info.... what exactly is the motor doing versus not doing? besides not starting
Re: 92 Civic VX - No start
Bone stock-- unmolested
Engine turns over fine new (today) battery
NO SPARK at any of the plugs
fuel pump primes..I can hear it.
Going to check fuel pressure next ...have not yet checked it because as I said no spark at the plugs
First post here.
Secondary: 11.9 ohm
Suggestions?
Thanks Gents
Secondary: 11.9 ohm
Suggestions?
Thanks Gents
pandax. Tks for the quick response.
I'd have to purchase a coil to try. no returns on electrical prts.
Cant seem to locate a procedural for testing the crank sensor. Is there one here?
Tks
Tks
How many wires have u got on it ?
Should be at least 3, ground, positive and signal.
Unplug the connector, and check voltage with ignition on.
Black wire is the ground, and try the one / two / three wires left.
Positive wire should be +12v and signal wires would change when cranking.
If no changes, sensor probably dead ..
Before buying parts, try to find a nice guy would could lend u those. Cheaper, and won't make u lose money
twocross
12-26-2011 12:04 AM
