Del sol b18b1 won't start
K guys real simple. Motor has been running just fine. This morning I try to start it to go to work it fires right up for about 3secs then just dies and won't restart. Any suggestions?
Re: Del sol b18b1 won't start
Well I had to go to work but there is no cels fuel pump is priming. It's timed cause it ran fine yesterday spark I have to check. And compression was good before but I should recheck it
Check whether the Blk/Yel wire attached to the coil and ICM has battery voltage with the key in ON(II). If so, Ohm test the coil and have an auto parts store test the ICM.
Or a DIY for ICM testing can be found here:
http://www.team-integra.net/forum/bl...eshooting.html
