98 ek with 96 gsr - high idle problem
98 ek with 96 gsr. idle is 2-2500. I took off the iacv cleaned it in solvent over night put it back on the idle dropped down to 1400. then I realized I didnt plug the sensor clip back in. idle went back up.
if I get another iacv will it work or should I go onto other things? what car would I have to get it from?
i read 96+ engines dont have a fitv. but I can see what looks exactly like one under the throttle body. I dont want to go in there cleaning it because its looks like a Bitch. is that the next step?
or does un hooking the iacv wiring and that happen show something?
thx!!!
thx!!!
Re: IACV quick help.
engine lights?
if so which codes?
make sure the engine light illuminates for 2000ms(2 sec) when turning key to II position before start.
if so which codes?
the engine light doesnt work. even with a new bulb so till I get that scanned I guess nothing I can do? I was hoping someone could tell me from what happend with that clip not being plugged in.
check for hissing and vacuum leaks also
Quick question, do you have the stock intake manifold? Reason I ask is because the skunk2 intake manifold fits both the 2 wire iacv and the 3 wire iacv. This can lead to some idle issues if you use the wrong one. BTW as far as i know when you unclip the iacv sensor, your idle is suppose to drop down.
If your engine is utilizing an OBD2 ecu you must check for cel's and let the codes tell you, an idle that high must be from a fault which would trip the sensor, soooo fix the engine light problem first, or plug an OBD2 scanner into it.
Re: 98 ek with 96 gsr - high idle problem
P72 obd2 until I get a jumper to run a chipped p28
Im searching for my scanner....Erase codes and go
From there
Stock manifold and tb.
Throttle plate is right shut and idle screw closed
From there
then erase them and check to see if/when they come back, most OBD2 codes will take 2 or more trips to come back so a few drives might be necessary.
If the fault comes back instantly after clear/reset then you have a fault in the wiring.
you want my opinion, I thing that something physical is causing the high idle
something like a vacuum leak, search and find the best way for you dor checking for vacuum leaks, it is not hard.
I'll look more today for the reader. It's not a fresh swap I'm pretty sure it ran somewhat normal in its history.
I mean erase them as in find the codes (ex knock sensor and o2 sensor) and have those disabled in the new basemap.
Motor has been in limp mode for a while it time to open her up
One open vac line one the tb I searched and it isn't or anything I just caped it off
CIVIC96DXcp
06-02-2006 05:58 PM
Slammed Ek9
04-07-2005 03:00 PM
