NEEEED HELP ASAP ANYONE PLEASE!!!!!!!!
OK MY WINDOW LIFT OR CRANK MESSED UP SO NOW MY WINDOW DOESN'T GO UP!!!!! AND ITS GONNNA RAIN SOON SO I NEED TO FIX IT ASAP WHAT I NEED TO DO IS TAKE OFF THE METAL PANEL WHERE ALL THE SCREWS GO TO SO I CAN FIX IT OR IS THEIR ANY OTHER WAY FROM WHAT I SEE THE GEAR CAME OFF OR SOMETHING LIKE THAT HELP ME PLEASE WITH PICS OR VIDEOS ANYTHING THANKS!!!!
98 CIVIC DX
98 CIVIC DX
Re: NEEEED HELP ASAP ANYONE PLEASE!!!!!!!!
Same thing happened to me in my 1994 civic coupe. I had to replace the entire window lift assembly, it actually broke. It only cost me 50 bucks installed from a local honda wreckers. wish i could help ya more but when the window drops down the lifter is usually broken and not usable anymore.
Take off the inner panel, not hard, screw under the door release, pull cup off. Screw in the pocket on the arm rest area. Take off the winder, I think it you need a flat head screw driver and you can release it. Pull off the panel it clipped on. See if you grab the glass and pull it up, look at the regulator scissor looking mechanism get you hand under it and see if you can raise the glass. At least this will get the window closed. It also can be off the run channel try to realign it. You will probably need a new regulator it is about 50 bucks or so.
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post.
aws140
07-18-2005 12:09 AM
RedDC5
02-20-2005 11:00 PM
Spooled1.6L
05-18-2004 05:17 PM
