D15B7 weak spark issue
ok so heres the deal my Buddie had a spark plug grouments leaking and he had oil to the top for 3 cly so i took it apart and redid the vavle cover and i was button it back up and started up just fine then about 2 min later it died and it will not fire back up it has orange spark ..now with that been said ive replace the coil,icm,plugs,plug wires,cap and rotar. now with that being said. ive thought the coil was the problem as weak spark but ive put on 3 that came out good dizzy the car had hard time starting last couple weeks and ive thought it was bad battery any help would be greatly appt i need to get his car back running ....oh ps the timing is dead on and its getting fuel just fine
Re: D15B7 weak spark issue
What is the voltage across the battery posts? What voltage reaches the Blk/Yel wire attached to the coil and ICM?
Has the ICM been tested?
Are all of the wire connections inside the distributor clean and tight?
97honda civic dx
18
04-12-2009 06:41 AM
Coolcat55
10
05-18-2007 07:36 PM
