EG8 - stalling problem
OK so I am having issues with my eg8. The car has a JDM d15 swap. I have replaced a lot of parts on it. The issue I am having is that the car is stalling out alot. The car seems to stall when I am coming to a stop and take the car out of gear and put it in neutral. It has stalled several times after sitting at a long light, then once I go to shift from 1'st to second gear it will stall occasionally (I know how to drive it's not cause I am a dumbass). Any way, the other issue is that the car does not want to start after I put gas in it (Almost everytime). It will begin to turn over and when I try to rev the engine it dies... I replaced my fuel filter, starter, dizzy, spark plug, wires, battery etc. so I am not sure what the issue is. Any suggestions would be greatly appreciated!
Re: EG8 - stalling problem
1) Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
2) Don't ignore CEL codes.
Pull the codes now and then reset the ECU to see whether the codes repeat.
Thank you. I will def. clean my FITV. I don't think that explains why the car doesn't want to start after I put gas in it though...
I got the following codes from my CEL: 9- CYP-Cylinder censor, 19- Automatic Transmission lockup control valve, and 21- Vtec spool solenoid valve.
templarvisonz
05-20-2010 03:02 PM
resqu417
Honda Civic (2001 - 2005)
10
12-17-2009 05:35 PM
Mike95lude
10-11-2005 01:00 PM
