EK QUESTIONS about cluster swap, blown dash lights fuse, and water leak
Alright guys i just have a few questions... should be pretty easy to answer... I drive a 96 EK DX
1) How hard is it to go from Stock gauge cluster to si cluster?
2) Dash lights behind cluster keep popping the fuses to fix the lights... easy fix? Grounding?
3) There is a crazy leak on the pass. side floorboard. Is that common? Hard to fix?
Thank you all of you that took the time to help or figure this out. And if any of u have questions i will be happy to reciprocate the gesture...
R.I.P. Mark
Re: xXxEK QUESTIONSxXx
1) plug n play
2) check that nothiong else has been wired into that circuit like the radio
3) Yes there are a couple of places ..pull the carpet back and you should find the sorce or do it and have a freind hose the car easyest way to find it
Re: EK QUESTIONS about cluster swap, blown dash lights fuse, and water leak
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
with the cluster swap I have a DX so no tach with an si cluster it does what is needed to make that work?
Prob. heater core if it is coolant that is leaking in the passenger side. If it is just water like only found during a rainy day then you will have to check door seals and seals on the firewall.
sol-oto
06-17-2018 08:56 AM
mrbsponge
12-31-2003 03:31 PM
