rear upper control arms.. eg and ek the same?
Old 05-17-2012, 12:42 PM
swizz977's Avatar
Default rear upper control arms.. eg and ek the same?
are they the same on the eg and ek or are they different the rear upper contral (camber) arms thanks
Old 05-17-2012, 01:29 PM
The Grumpiest
grumblemarc's Avatar
Default Re: rear upper control arms.. eg and ek the same?
.Same? No.
Old 05-17-2012, 01:31 PM
swizz977's Avatar
are you sure because they do have the same part number..
Old 05-17-2012, 01:56 PM
s13hero's Avatar
What do you mean by rear upper control arms? There is a rear lower control arm, and a rear trailing arm. If you are asking about the rear lower control (compensator) arm than EG and EK are NOT the same, if you are asking about the rear trailing arm then the arm itself is the same, of course the brakes differ.
Edit: N/m I see you indicate the "camber" arm, in that case yes, EG and EK are compatible
Old 05-17-2012, 02:07 PM
I like to party
2LEM1's Avatar
Yes, the camber arm is the same on all 92-00 civics.
Old 05-17-2012, 03:57 PM
The Grumpiest
Sorry. I somehow read that as front. Still won' fix your issue.
Old 05-17-2012, 04:23 PM
I like to party
2LEM1's Avatar
.... what's his issue?
Old 05-17-2012, 06:01 PM
The Grumpiest
For months he's had one of the welded nuts break off and he cannot and will not use any of the solutions that have been given to him to fix it.
Old 05-17-2012, 08:01 PM
I like to party
2LEM1's Avatar
You should be used to that by now
Old 05-18-2012, 03:04 AM
The Grumpiest
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rear-upper-arm-bolt-question-1992-civic-3012427/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1992-civic-hatchback-rear-camber-arm-bolt-wont-tighten-2996852/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ek-rear-camber-kit-install-broken-bolt-help-2898712/
And this one is one of my all time favorites.
why does my skunk2 camber kit keep loosening while driving
Old 05-18-2012, 05:27 AM
jbpnoman's Avatar
Here's the tl;dr version. His issue is that he knows nothing about cars, wants to run hella flush with 20 degrees negative camber, doesn't want to talk care of his car, and expects us to give him a 5 minute fix to all of his issues.
OP, if you've already looked up the part number, why are you even asking?
Vi3tsi06
Suspension & Brakes
28
09-09-2010 10:05 PM
BrianFreels
05-04-2009 01:36 PM
TotalBalance
Suspension & Brakes
11-20-2007 09:37 AM
FLATBLACKEG
08-15-2006 02:35 PM
FLATBLACKEG
Suspension & Brakes
08-15-2006 02:17 PM
Quick Reply: rear upper control arms.. eg and ek the same?
