92 civic brake light and horn fuse blowing when i step down on brakes
Old 05-21-2012, 05:00 PM
99civic4dr's Avatar
Default 92 civic brake light and horn fuse blowing when i step down on brakes
brake light and horn fuse keep blow when i step down on brakes
i have replaced the brake switch, torn up the whole interoir found no bad wires, checked all grounds, bulbs and their sockets and the werid thing is that all the lights work like high and low beam, dash lights, signals, and even the tail lights but has no brake light when pressing on the brakes
Old 05-21-2012, 05:03 PM
Former User's Avatar
Default Re: 92 civic brake light and horn fuse blowing when i step down on brakes
Unplug the rear connectors for all three brake lights. Does this prevent the fuse from blowing?
Old 05-21-2012, 05:11 PM
99civic4dr's Avatar
yup tried that too still blows the fuse
Old 05-21-2012, 05:14 PM
There's a wire short somewhere between the pedal switch and those rear connectors. If you can locate any connectors in between the switch and the rear connectors, then unplug them to see whether the fuse stops blowing.
Old 05-25-2012, 02:04 PM
99civic4dr's Avatar
yeah so i take out my dash and traced the wire from the brake light switch to the fuse box and there is not a single thing wrong with it and unpluged the main harness going to the back and still keep blowing the fuse
Chris_A
07-28-2017 08:54 AM
Type-Spaz
10-02-2011 04:44 PM
dbailey
07-25-2010 10:24 AM
ATLHONDA
03-22-2010 04:34 AM
vteghatch
01-13-2006 10:48 AM
Quick Reply: 92 civic brake light and horn fuse blowing when i step down on brakes
