ecu sohc v-tech
ecu sohc v-tech
hey everyone.. workin on my turbo car.. recently purchaced a
1997 civic hx 1.6 d16y7 bottom end with a y8 head. with v-tech.
just wondering what ecu i can run...
currently in the car there is a p2N this is a NON v-tech ecu if i have read correct.
The v_tech ecu is the p2M.. ?
but my v-tech is still kickin in right where it should be... and im not throwing any CEL lights...
please share some info with me on what you know!
Technical Hero
Re: ecu sohc v-tech
P2P is the correct ECU. How do you know it's the Y8 head? Could be the Y5 head with a Y7 block as both are VTEC. Take some pics with the valve cover off to confirm. The P2N is a VTEC ecu for the Y5 VTEC-E engine.
The Grumpiest
Re: ecu sohc v-tech
If you're boosting you'll have to get an OBD1 ECU that can be socketted and chipped to run a basemap at the very least. P28. YOu should not run a stock ECU on a turbo'd engine.
Re: ecu sohc v-tech
thanks for the input... just ordered my obd2 - obd1 jumper... already have a socketed p28 ecu just wasnt sure if it would work or not!
Thanks a million hopefully starting my build soon
DetainedCivic
04-18-2006 04:47 AM
