So what i i suppose to do when my air conditioniner makes a fujnny noise?
when i drive with my aconditioner on it usually makes a squeaking noise whenever the cpompressor engages so why do it do this, is the clutch sticking or something, it makes buig jerk wehn it enages, really noticebale espcecially with the squeak so whaty do you suggest i do?
***edit*** thanks guys cannoty respond sinc ei have uer restirction will do 2moror
Modified by westsidejdmyo at 1:22 AM 11/8/2003
Re: (CXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">Mine stopped the squeak when I tightened it</TD></TR></TABLE>
yep tighten up bro!!
Risky Business
Re: (westsidejdmyo)
It wont work. Its not the belt...its the compessor clutch. It happens with all of the Honda's that i've come across. If you watch your AC compressor, when it makes the sound the thing will kinda stop, and keep going again, it looks like it gets stuck then keeps going again. But its fine, I talked to a Honda mechanic and he said its normal. The sound is annoying though But I've learned to deal with it
Re: (BauleyCivic)
cheers bauley, good info as usual, not worried much about the sound, most annoying bit is actually feeling it kick in - car jolts very slightly but anyways at least i now know its common...
Risky Business
Re: (westsidejdmyo)
Yep, mine does too, as does my brothers 99 EX. The jolt is annoying...I just try to use the A/C as little as possible. But yeah, dont worry...mines been doing it the entire duration that i've had the car (3 years) and the A/C still works and blows cold
kihun_cha
12-03-2005 07:24 AM
turbo95eg6
11-10-2005 09:26 PM
