96-00 DX Tranny Question
I recently did a tranny swap from auto to 5spd. Ok everything is good, BUT i've noticed everynight i get 2-3 drops of oil on my driveway. The oil drips seems to be coming from the side of the tranny. So anyways, I recently changed my clutch and noticed there's not a plate that hides/protects the flywheel, and was wondering can oil leak out from there?? any suggestions are appreciated. Later ya'll
Re: 96-00 DX Tranny Question (ek9 ferio)
that sheild is a dust/rock sheild...dont worry about it to much...
if your worried about the leak, take a peek and try and trace it...sometimes the tranny drain plug isnt tightened enough...
D Tranny Guru
if oil is leaking from the tranny area (WTF is the cover??) likely it is a rear main seal.
I've never had or seen a leaky tranny or rear main seal, YET!~
Re: 96-00 DX Tranny Question (HXMan)
Yea, many of my friends have told me that it may be the rear main seal. thanks ya'll, i'll try to look harder and trace to see where the leak is coming from. btw...is the rear main seal a biatch to change??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9 ferio »</TD></TR><TR><TD CLASS="quote">is the rear main seal a biatch to change??</TD></TR></TABLE>
only if the balljoint is hard as **** to remove...... check FAO Axle Tutorial. anytime "oil" leaks from the tranny..... 90% of the time it is the axle seal
Re: 96-00 DX Tranny Question (Jswpstdoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff »</TD></TR><TR><TD CLASS="quote">
anytime "oil" leaks from the tranny..... 90% of the time it is the axle seal</TD></TR></TABLE>
damn! now that i think of it, u may be right. I notice that the oil comes around the axle near the tranny side. How does the seal to that look like?? is it just a rubber washer??
it's a big circular shaped piece of rubber that goes around the hole in the transmission where you stick the axle in. you can get a new one from Honda for pocket change. just be careful not to fu** it up when you put the axle back in. i've done it before.... PM me if it gets to difficult.
use this as a guide
good luck. hope you've got a garage. when i changed mine it rained all over my ***. never work on your car when you have to be somewhere later in the day.
