suEKpsension tehcniques swaybars install instructions HELP?
well i bought some ST sway bars front and rear from a guy... and i cant find the instructions anywhere to install them... theres bolts and bushings and i dont know how to put them together... the rear doesnt even look like a OEM SI sway bar... haha
this is for a 97 civic EX...
Re: suEKpsension tehcniques swaybars install instructions HELP? (Laosfu)
ST has some horrible Quality Control. I got a set of springs from them and the fronts and rears were mislabled.
Basically, the bars should be the same shape as the stock bars you are removing, just a larger diameter.
It's best to put your car up on ramps when removing and installing the bars. You don't want the tires off the ground.
If you have the poly bushings, there should be a lubricant supplied with them to reduce squeaks.
I'd call ST and see if they could fax you a set of instructions.
Re: suEKpsension tehcniques swaybars install instructions HELP? (323GTX)
i know which bar is which... cause the over design... but the mounting point dont look like stock is what im trying to say... is there a ST website? or number? cause i cant find that either... GOOGLE sux *** cause all the crap on there now...
Alucard-1524
04-16-2011 05:03 PM
Raocorp
12-09-2003 02:09 PM
