HELP!*tried search cant find where to check codes!
6th gen Si coupe. as title says.
just installed HKS catback exhaust. now check engine light is coming on. where do we look to find the codes?
thanks in advance
thanks in advance
Re: HELP!*tried search cant find where to check codes! (97DX)
http://www.c-speedracing.com/faq/06.php
there ya go. i dont think you searched very well....
all you do is pop that thing out, stick a paper clip in both terminals to jump it, and count the flashes.
they tried that while i was here. i found that earlier, when i was searching. and there was nothing there under the dash.
pcm is behind passenger side kick panel. there should be a 2-pin connector tied to one of its harnesses. jump the 2 terminals...first digit of code will flash slow...2nd digit flashes rapidly. if it's only one code, the pattern repeats. obd2 codes are all standardized, except for manufacturer-specific.
Lucky-R
11-13-2006 05:36 AM
bluebomb
01-28-2004 05:48 PM
