car wont "warm up"
car wont "warm up"
so i just put my new LS motor in the other day and when i drive my car, it wont "warm up" so to speak.
the motor idles higher when its cold, and drops when after running for a few minutes like normal, but it wont warm up. like the radiator/hoses are all still cool to the touch and the temp guage doesnt move even after i've been driving it for a few minutes
my first thoughts were about the thermostat, but than the car would overheat correct? than i thought about the sending unit for the water temp, but that still wouldnt explain the coolness of the radiator, and hoses. could it be both?
thanks
thanks
New User
Re: (Mighty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mighty »</TD></TR><TR><TD CLASS="quote">Thats a stuck open thermostat. It happens.</TD></TR></TABLE>
i have the same problem. changed the thermostat and it didn't fix the problem.
Re: (Unjockable)
thermostats don't usually stick open. but anything can happen with cars.
there might not be a thermostat in there period. When I got my swap only half of the thermostat was in there so the car would never warm up
OG triple OG
Re: (dantastic)
not having a thermostat isnt smart , youll get alot of corrosion inside . and thermostats are "Designed" to stick open when they go bad , however they never do 99% of the time. so thats what it sounds like to me , or somehow your fan is on all the time
If the theromostat doesn't work...My friend had a problem with his integ not warming up, along with a small unnoticeable leak from I think the IAC gasket...the little rubber 8 gasket on the back of the manifold. Once he did that...it worked fine. Might not be the cause...but you never know...caused a similar problem.
Re: (H23 EG Hybrid)
Thermostats stick open often especially on motors that have sat for a while and then get put back into use. Mine was stuck open and wasn't a issue till the temps got down and it would take 15 minutes of driving to get any heat.
yea judging by the looks of the stock clutch, the motor did sit for a while, i just bought a new thermostat today, as well as an o2 sensor so hopefully my car will be running great again by tonight
4DRmafia
02-03-2005 11:40 AM
