Gauge Instrument Cluster Not Working - Looking for Civic Diagrams
Hello Everyone,
I did a search already and have come up w/ Hazard Fuze, Fuzes, etc. etc.
This is what works:
Battery Light
Signal Lights (When Hazard Light button is pushed)
SRS Light (Since my airbag is disabled)
Dimmer Lights (When Headlights Are On)
This is what doesn't work:
RPM Gauge (Tachometer)
Speedometer
Fuel Gauge
Water Temperature Gauge
Oil Light (When starting the car it usually comes on)
Signal Light (When trying to signal left and right)
I checked the fuzes under the hood and under the drivers side, and none of them are blown. I replaced my gauge cluster, and it's the same problem so it's not the gauge cluster.
I have a 1992-1995 Honda Civic EX Coupe.
Any other suggesstions?
Any one have 92-95 Civic Diagrams? I need to trouble shoot the 13 and the 10 pin connectors...
This is what works:
Battery Light
Speedometer
Fuel Gauge
New User
Re: Gauge Instrument Cluster Not Working - Looking for Civic Diagrams (cpforyou)
did you jus install those indiglow face plates or something? if you havent screwed with any of the wires
i say check fuses. check connections. no idea on your prob.
Re: Gauge Instrument Cluster Not Working - Looking for Civic Diagrams (Mr. Choi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi »</TD></TR><TR><TD CLASS="quote">did you jus install those indiglow face plates or something? if you havent screwed with any of the wires
i say check fuses. check connections. no idea on your prob. </TD></TR></TABLE>
No, it's a stock 92-95 Civic Gauge Cluster.
HELP! Instrument Gauge Cluster Not Working Fuel Water Temperature Temp Speedometer Tach Tachometer S
cpforyou
05-16-2004 08:22 PM
