why is it leaking from here?
i wnat to know why and how could i fix it..oil is leaking from my shiftlinkage...what would be the reason and how would i go about fixing it..thanks
Re: why is it leaking from here? (EG Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic »</TD></TR><TR><TD CLASS="quote">how do you fix it?
what needs to be done what do i need to buy? it's a d15/vtec</TD></TR></TABLE>
Go to honda.. and buy a tranny seal for what ever year the tranny is SOHC... and you have to take out the driver side axle and replace the seal.
D Tranny Guru
Re: why is it leaking from here? (widebodyEg16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by widebodyEg16B »</TD></TR><TR><TD CLASS="quote">you have to take out the driver side axle and replace the seal.</TD></TR></TABLE>
BUZZZZZZ.........wrong.
Drain tranny oil first!
To replace the shift shaft seal, unbolt the shift linkage from the tranny. Using a screwdriver pry the old seal out, then use a socket and small hammer to drive in the new seal.
Here is what you need.....the shaft seal is the same on every Honda tranny I've ever worked on.
http://www.slhondaparts.com/br...3-005
hatchinprogress
01-16-2006 11:46 PM
