ls axel problems
ls axel problems
Problems installing my axels on my 2000 hatch with swap. Not sure how they go on the hub. The one side is installed on the tranny, but the other side where it goes thru the rotor i'm not sure of. The shock tower connects to the lower control arm, and then to the strut. Does the axel go thru that little space ?
1 Post
Re: ls axel problems (Jdm Ek Hatch)
the axle goes through the fork on the shock if that's waht you mean...you'll have to remove the 17mm nut and bolt that holds the shock fork to the LCA and remove the 12 or 14mm(can't remember which)that holds the fork to the shock.remove the fork and seperate the lower ball joint on the spindle.throw the axle in and do everything in reverse.you should really invest in a shop manual-it'll answer just about any question you have without having to wait for a reply.
chris
chris
Re: ls axel problems (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">the axle goes through the fork on the shock if that's waht you mean...you'll have to remove the 17mm nut and bolt that holds the shock fork to the LCA and remove the 12 or 14mm(can't remember which)that holds the fork to the shock.remove the fork and seperate the lower ball joint on the spindle.throw the axle in and do everything in reverse.you should really invest in a shop manual-it'll answer just about any question you have without having to wait for a reply.
chris</TD></TR></TABLE> thanks for the post, i pulled the stock engine, but forgot how it went, i'm planning on getting one. Should of got one before i started the swap but i was to lazy. Thanks again for the info axels in and car is sitting thanks.
erikiksaz1
Suspension & Brakes
11-02-2008 05:10 PM
B18CYAAA
10-25-2006 02:29 PM
