99 ecu in a 98?
Re: (joker4096)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joker4096 »</TD></TR><TR><TD CLASS="quote">i think without a conversion harness, it will not work. 96-98=OBD2A 99-00=OBD2b</TD></TR></TABLE>
yes like he said. you'd need a conversio harnes....but why are you trying to do that?
Re: (reaction360)
i'm trying to do it because i an throwing the infamous p0133 and i've replaced the o2 sensor 3 times now and its still doing it. i'm not having any luck finding a 96-98 close to me and i knew someone with a 99
Re: (sicones)
i spent 91 bucks from carquest for a bosch o2 look just like the one i pulled off..and i tried two of my buddies universal all with out any luck!
Re: (ej8luver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8luver »</TD></TR><TR><TD CLASS="quote">i spent 91 bucks from carquest for a bosch o2 look just like the one i pulled off..and i tried two of my buddies universal all with out any luck!</TD></TR></TABLE>
did you reset ecu afterward?
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">you do realize you have two o2 sensors right???</TD></TR></TABLE>
Funny chit.
Funny chit.
Re: (B20 EJ6)
ya i do realiz all that ****..i'm not a complete moron...i pulled the code up on my scanner its the o2 slow response bank 1 ....implying before the cat...and yes i did pull my positive on my battery to clear the code and it came back on 2 days later.
Re: (ej8luver)
usually you unplug the negative terminal to reset ecu, but if it work for you than it works. I would try to fool the ecu with the spark plug fouler trick. If that doesn't work, you might be reading the code wrong. It could be your cat converter
Re: (ej8luver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8luver »</TD></TR><TR><TD CLASS="quote">i pulled the code up on my scanner its the o2 slow response bank 1 ....implying before the cat...</TD></TR></TABLE>
Bank 1 means on the side of cylinder 1. That is only relevent to RWD V-engines. It should say Bank _, Sensor _ (1 or 2). The Sensor number tells you which o2 sensor to replace.
PhatBoy5015
33
10-29-2017 11:42 AM
