clutch pedal help
Old 06-17-2006, 09:35 AM
NeWnMpR0VeD's Avatar
Default clutch pedal help
i turned my car on... and my clutch pedal has been making a squeeky noise when its not in engaged... u can say its normal... but yesterday i went under the hood... and i was pushing that lil thing that sticks out the transmission, its connected to the pedal tho... i was pushing it shut n open... and now my clutch pedal will fall right to the floor when i barely touch it... LOL i'm a dumb ***... now how do i get it back to normal
Old 06-17-2006, 09:42 AM
philosofy1's Avatar
Default Re: clutch pedal help (NeWnMpR0VeD)
sounds like your slave cylinder is bad. it needs to be replaced. imo, replace both the slave and master cylinder, bleed the system and everything should be back to normal.
Old 06-17-2006, 09:50 AM
JDMroyEG5turbo's Avatar
Default Re: clutch pedal help (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your slave cylinder is bad. it needs to be replaced. imo, replace both the slave and master cylinder, bleed the system and everything should be back to normal.</TD></TR></TABLE>
Old 06-17-2006, 10:17 AM
Default Re: clutch pedal help (JDMroyEG5turbo)
damn its that serious... all I did was touch one thing cuz I was curious... previous to that the pedal was fine... until I touched it... now the clutch pedal is so loose that if I push it down... it won't go back up
Old 06-17-2006, 10:25 AM
philosofy1's Avatar
well, that was probably a coinsident. it was probably on the way out the door anyway. they're not hard to replace, and fairly cheap to buy. imo the hardest part of the whole deal would probably be bleeding the system. and even then it's not that bad.
Old 06-17-2006, 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">well, that was probably a coinsident. it was probably on the way out the door anyway. they're not hard to replace, and fairly cheap to buy. imo the hardest part of the whole deal would probably be bleeding the system. and even then it's not that bad.</TD></TR></TABLE>
damn it, i'm clueless as where to start...
Old 06-17-2006, 11:21 AM
philosofy1's Avatar
pick up a repair manual and follow the steps, you can't go wrong!
Old 06-17-2006, 11:28 AM
thank u very much
Old 06-17-2006, 11:46 AM
crimsonv4mpire's Avatar
a new slave is like 30 bucks, i think 2 14mm bolts(?) and a 10mm line wrench.. if all you'll need tool wise.. make sure it's a line wrench, you WILL strip it outherwise.. i made the mistake for a few seconds, and almost screwed myself.. but it's a simple repair
gooblinn258
01-18-2014 05:02 PM
TheAccordGuy
11-09-2006 04:41 PM
vlc92189
11-06-2006 08:49 AM
FuNkDrSpOt
10-10-2006 09:48 PM
puertoroc7976
09-07-2006 03:06 PM
Quick Reply: clutch pedal help
