!!!!!!!need help now!!!!!!!!!
I have a 99 em1 that i am trying to put back together i swapped in a obd2 ls motor with a type r tranny every thing is in but when i try to crank it , its like the starter is not getting any single from the ignition . i have checked the starter and its good all fuses are good interior harness is perfect battery good every thing else works radio , windows, lights , sunroof etc. the only thing i could think of is it because im using an ex harness. if anyone has any ideas please hit me up. i am about to give up hope.
Re: !!!!!!!need help now!!!!!!!!! (nalos)
Your wiring is messed up. Probably a cps/ignition-related sensor. What ecu are you using and what cel are you throwing?
Im using a p2t . i havent checked what the cel is throwing but even without a computer u would hear the motor try to crank and the starter would get a signal. all i here is a click from the fuse box but not from the starter.
if you are capable of a swap you should be able to logically figure out what is wrong. check the signal at the starter, if there is none, then you might have a bad clutch safety switch. if the signal is there as well as 12v+ you most likely have a bad starter.
i bought a new clutch switch so its not that. and the starter is not bad checked that too. Could it be because im using an ex harness
Re: (EM199dcs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM199dcs »</TD></TR><TR><TD CLASS="quote">well I would think since your using a ex harness it wouldnt work. Get the right harness for that swap in that car.</TD></TR></TABLE>
Your wrong. Nothing wrong with that harness.( it actually happens to be my favorite for obd2 civic swaps)
Try to manually jump the starter.(Ground the power source on the solenoid) If that works, your ignition switch is bad.
Unceasing Measure
Re: (nekoabandoned)
Strange **** happens when the engine is ungrounded. Toss some wires on the block and tranny case and thermo-housing and make sure they're attached to the firewall or core support or frame rails or something and then try again. I'm sure it'll start.
