K20A in Civic EG
Re: (3.5vteccivic)
I guess I'll take the hit;
In regards to why you need 10K is because,
1. The motor willl run approximately 4-6K
2. Mounts from Hasport will run 800
3. You will need to have the fuel system converted 300
4. You will need to run hondata = 1K
5. Labor will probably be 1K
So yea, all in all youre looking at a swap that will run you anywhere between 8-10 grand. Good luck!
K20.org is a good site for reference or questions.
Re: (Nah-Roo-Toe)
8K if you cut corners but whats the sense in that if you could do a B-series that performs just as well
Set up:
jdm k20a
hytech adjustable length header
t1r ek midpipe
hytech twin loop axle back exhaust
RBC intake manifold w/Speedwerx adapter plate
hondata intake manifold gasket
custom CAI piping (MOTO-C)
PrototypeRacing velocity stack w/K&N filter
Toda Flywheel (8.1 lb - chromoly)
Exedy stg2 cerametallic clutch
Hasport axles (stg1)
Hasport mounts (ekk1)
hasport fan switch
Aeromotive FPR
custom fuel line set up (-6an aeroquip startlite lines, earls ano-tuff fittings, earls fuel filter, marshall shock proof FP gauge)
golden eagle fuel rail
walbro 195 fuel pump
C&R 1/2size radiator w/Karcepts mount
Spal 1200cfm 12" slim fan
K-pro
Karcepts shift kit
Suja-1 motoring custom clutch line
RSX-S clutch slave cylinder
ep3 ('02-'05 si) idler pulley
autozone 50.5" 7-rib belt
carbing oil catch can (mod'd)
granted you NEED everything I listed but you will NEED most of it
the POS
Set up:
jdm k20a
t1r ek midpipe
hasport fan switch
Aeromotive FPR
K-pro
Karcepts shift kit
the POS
cute little bastard
Re: (_adirondackR_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _adirondackR_ »</TD></TR><TR><TD CLASS="quote">8K if you cut corners but whats the sense in that if you could do a B-series that performs just as well
Set up:
jdm k20a
t1r ek midpipe
hasport fan switch
Aeromotive FPR
K-pro
Karcepts shift kit
the POS
lol do you ever get sick of listing all that for someone?
Set up:
jdm k20a
t1r ek midpipe
hasport fan switch
Aeromotive FPR
K-pro
Karcepts shift kit
the POS
Re: K20A in Civic EG (3.5vteccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.5vteccivic »</TD></TR><TR><TD CLASS="quote">I was wondering if somebody would help me to swap a k20 in my eg like step by step guide</TD></TR></TABLE>
Do some research, dont expect other ppl to guide you...gotta learn for yourself so you'll know what and what to do and wont have to rely on otther ppl...but for going k20
Re: K20A in Civic EG (..::ferio::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::ferio::.. »</TD></TR><TR><TD CLASS="quote">
Do some research, dont expect other ppl to guide you...gotta learn for yourself so you'll know what and what to do and wont have to rely on otther ppl...but for going k20</TD></TR></TABLE>
lol...what ever you do don't buy a k20a3 motor
actually here is a very informative thread
https://honda-tech.com/zerothread?id=1274311
also go to http://www.k20a.org good luck take your time & have lots of patience
Re: K20A in Civic EG (_adirondackR_)
yhea, he'll need a good chunk of change. But I have a friend that just finished a CRX with a 1st generation K-series swap, and the shell included, and ecu and all. under $5k($4900). plus a k-series is worth it, just don't give info that's not exact cuz you don't look smarter doing it, just let them spend whatever THEY want. good luck with the k-series. we expect 12.6-12.8 out of our k-series.
Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">lol do you ever get sick of listing all that for someone? </TD></TR></TABLE>
I'm sure he copies and pastes lol.
Re: (jidumEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jidumEG6 »</TD></TR><TR><TD CLASS="quote">you know where i can get a EG6 si shell</TD></TR></TABLE>
uhhh.. just check around your local area... check marketplace once you're not at trial status anymore or whatever
cute little bastard
Re: (RockLee`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` »</TD></TR><TR><TD CLASS="quote">
uhhh.. just check around your local area... check marketplace once you're not at trial status anymore or whatever</TD></TR></TABLE>
lol yes he is, says it bright and red under his username
