brake booster help...?!?
So I got rid of ABS but kept the ABS MC and booster and just flared a new fitting onto the none ABS lines. I bled the brakes and all that good stuff, got a stream of fluid to squirt out on all 4 wheels. The brake is still mushy as ****, when i pump it it gets stiff but then it lets out and the car bogs down. If I do this with the car of it gets stiff and then when I start the car it rev's til like 2-3k and then idles fine unless I play with the brake pedel again. Any help would be great, could the little plastic valve between the IM and brake booster be shot by any chance? Thanks
EDIT: If the orderer you bleed the wheels was wrong would it make a big difference? Thansk
Modified by simple DB2 at 12:09 PM 6/17/2006
i figured since it was doing so maybe it had something to do with vacuum. all i know is i hope its not the booster cause i cant be bothered with that ****.
Re: (simple DB2)
If the pedal is mushy while depressed normally, but stiff if it is pumped a few times first, the main seal inside the master cyl. is bad. Fluctuating idle while the pedal is depressed several times is normal. If you hear somewhat of a vacuum leak (air moving) while the pedal is depressed, the booster is leaking internally and needs to be replaced. Test the fluid in the master cyl with a copper testing strip. Or, check to see if there is any black film in the master cyl reservoir.(also signs of the master breaking down)
Re: (B20 EJ6)
Tell tale sign: Slowly depress the pedal. Go all the way to the floor?
Pump the pedal fast three times and hold on third. Go to floor?
Yes/no = bad master
No/no = No problem
Yes/yes = Air in line
No/yes = impossible; your lying.
kthksbye
Yes/no = bad master
No/no = No problem
kthksbye
Re: (B20 EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">I already gave you the answer. But oh well, baffle yourself and keep guessing. Glad its not my car.</TD></TR></TABLE>
well your answer was wrong but thanks. it ended up being something as simple as the wrong bleeding pattern.
