civic si brake mounts?
Grrrr tapped return and it post that.
im a bit confused, im trying to find out if integra type R calipers fit on 1992-96 eg si knuckles ?, here in the UK its called a civic VTi with discs front and rear, any one done this ?.
Re: (flangemastermike)
Which ITR calipers are you referring to? 96 spec or 98 spec? 98 spec, you would need new caliper brackets to push the caliper further away from the hub since it's larger. But using the stock rotors, you won't get much braking surface. 96 spec are like our regular Integras which can be modded to your knuckle using regular Integra rotors. Again, you will need to space them out from the hub.
blacktibby07
13
05-17-2011 03:00 AM
