eg with a gsr trany problem...... help please
i have a 94 civic coupe with a gsr swap. it wont downshift cleanly into 2nd, every other gear transition works fine, but when i try to go into 2nd, i have to stick it up into 1st before it will go into 2nd. any ideas on why this happens, and what i can do to get it to stop. it makes driving the car just a little tricky. could it be the shift linkage? thanks for the help!
B A N N E D
Re: eg with a gsr trany problem...... help please (spoolinegsr)
cheapest things to try is change tranny fluid and change oem bushings out for ES poly bushings. IF it still doesn't help, you need a new 2nd gear synchro set which is about $180 from dealer plus labor. Hope the first 2 help!
B
B
