Clock is dim and no radio in EG
the clock is super dim and the radio will not work. and every time i turn the car off the clock resets. i checked the radio fuse and looks to be good.
justin
oh and it suck to be driving with no radio
justin
Re: Clock is dim and no radio in EG (doggworld1233)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 »</TD></TR><TR><TD CLASS="quote">the clock is super dim and the radio will not work. and every time i turn the car off the clock resets. i checked the radio fuse and looks to be good.
justin
oh and it suck to be driving with no radio</TD></TR></TABLE>
check the fuses under the hood, and under the dash. if for some reason they are good or if you just replace them, then it is a loose wire. most likely a ground. had this happen to me before.
justin
Re: (doggworld1233)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 »</TD></TR><TR><TD CLASS="quote">it was the back up fuse just replaced it and all is good</TD></TR></TABLE>
SLOAZZ95
10-06-2003 09:32 PM
