no power to gauges, car wont start, what fuse is it?
I believe a fuse has gone out, i have no power to my gauges and my car wont start. Battery is good. Any suggestions? Thanks
Re: no power to gauges, car wont start, what fuse is it?
I would look at you maxi fuse if nothing is working. Make sure the connection to your battery is good at negative and positive. Would check dash fuses using a test light underneath the dash also.
What electrical components do have power? Does the starter crank the engine but it won't start? Or does does the starter fail to crank the engine?
headlights work fine, car wont even crank at all. When i turn the key to the on position, my gauges wont light up. I have no power to even start
my car was working fine up to this point. My car was stolen, the ignition coil was hanging under the steering wheel, i tried to put it back in place. After doing that, there was no power whatsoever. So there must be a short somewhere
TIRENECK
03-02-2019 11:16 AM
Jokester
04-13-2010 01:13 PM
