Constant Metal scraping when rolling.
Car definitely does not feel safe to drive, there is a constant scraping sound coming from what I believe to be the wheels. Upon discovery I replaced brakes and rotors hoping that that would solve the case. Bt to my dismay, it actually worsened the situation. braking doesn't seem to quiet the braking as long as the car is rolling here's scraping. I THINK it may be bad wheel bearings but I'm going to take it to a shop soon. I just wanted a heads up. thank you!
Re: Constant Metal scraping when rolling.
Put your hands on the top and bottom of the rotor see if you can move it in and out. if not your wheel bearings are fine. Did you check your dust shields
It's stock height, the dust shield has been looked over and there's no issue with it. one thing I noticed... one of the sides. I removed the rim, caliper, pads, and rotor and spun it freely... but there was still scraping sounds...
those heat shields are sometimes a pain to get adjusted correctly.
so even when I remove all brake components (rotor, caliper, pads) from the assembly and spin what's left of the axle, the dust shield can still scrap against stuff? because I took it all off and there was with a slight scraping sound when I hand turned the axle.
roc0487
10
04-08-2013 03:32 PM
T--Rex
05-12-2005 02:22 PM
743power
03-29-2004 05:04 AM
