car not moving after start !! HELP!
k well after i start my car and start to drive it off it wont go anywhere my foot will be to the floor....for a few seconds it wont do anything all the sudden it will burst into power...and keep doing these random surges for a good while...then after a bit of driving it wont do it anymore...and sometimes if im at a stoplight for a bit itl be in neutral and car will be at operating temp and everything and itl just die. dirty throttle body/ vac leak? or is there anything else it COULD be.
Re: car not moving after start !! HELP!
do you have the clutch in and not letting it out? LOL anyway im lost as to what your saying when you floor it and not move and as for it dying, do you have any CEL?
k well after i start my car and start to drive it off it wont go anywhere my foot will be to the floor....for a few seconds it wont do anything all the sudden it will burst into power...and keep doing these random surges for a good while...then after a hard bit of driving it wont do it anymore.... dirty throttle body/ vac leak? or is there anything else it COULD be. im also running open header....94 dx with a b16 swap/b16 hydro trans. and the idols are very rough and if im stopped at a light it will idol like not even to 200
ok check you clutch master cylinder is not bad you might have to replace it or check for fluid on your clutch that was happening to me then i change it an it ran fine
You have sooo many reasons for it to run like ****. No o2 sensor, trouble codes that you haven't pulled, the open header. You really need to get all that fixed. Don't guess as to why its runnin bad. The answers are all in front of you.
OP, get more info, like fix things and pull the codes, and holla back
PotatoePAPA
01-28-2004 06:20 AM
