car problem
car problem
when i drive my whole car shakes as if one of my tires are uneven buts they all are and i want to know wat can be.????...i have a friend that says its my upper ball joint or my outter tie rods can that be...cause it shakes even harder on the high way when i hit it but its not as bad just cruzing on the high but at low speed and when i hit it it shakes really bad...
Re: car problem
Check for a bent rim or a bubble on a tire. If you don't find anything obvious there, then have all four wheels balanced. You might also want to check your axles and motor mounts.
