Where do I find the ignition wire?
Guys,
I am installing a GReddy gauge and I need to tap a wire to the ignition wire on my 94 Civic. From the search on this forum, the ignition wire is yellow/black color. Where can I get an easy access to the ignition wire? Any idea? Pics would be great!
Re: Where do I find the ignition wire?
Civic_driver,
Can you tell me wehre is the ignition switch? You are not talking about the key switch, aren't you?
Is there any place where I can have a easy access to the ignition power wire?
Yes, the key switch. The ignition wire should be somewhere in the back of that switch/cylinder. You already have the colors of the wires so it shouldn't be too hard to find.
Btw, you can also get the ignition wire at your headunit if that makes it easier for you. Depends on where you want the gauges to be. If they'll be on the driver's side then use the ignition switch, otherwise if they're in the middle somewhere, use the wire from the headunit.
