B18c1 will not go past 4,000 rpms
Just got done putting in a b18c1 with a p30 ecu and when driving the car it will not go past 4,000 rpms and will not pick any speed, what the hell is wrong?
Re: B18c1 will not go past 4,000 rpms
Agreed.
In nearly all cases, this is because your VTEC solenoid is not properly hooked up and/or broken.
Also, you might look at this thread
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b18c1-not-engaging-vtec-new-solenoid-oil-switch-no-cel-new-harness-2480698/#post37859903
Might have useful info.
samething happened to my buddys jdm h22 it almost hit like a limiter at 4k we switched his ecu to a p28 that was chipped and it solved the problem
Not to sound bad or anything but a friend of a friend was having this same type of problem. After going through many things it was something dumb, he had less than a quart of oil in it. Once he put more oil in, it worked again. You never know...
ensang_phamily
14
05-31-2009 11:46 PM
