88-91 and 92-95 struts
Old 04-24-2009, 02:22 PM
Swansen's Avatar
Default 88-91 and 92-95 struts
Just so everyone knows, and after a lot of misinformation, the rear struts on a 88-91 civic do no fit, correctly, to a 92-95. The rear fork/bracket that goes over the lower control arm is skinnier on an 88-91 than on a 92-95
Old 04-24-2009, 02:50 PM
sde780's Avatar
Default Re: 88-91 and 92-95 struts
You need the right LCA's to fit them. The LCA's bolt right in as far as I know
Old 04-24-2009, 03:01 PM
Swansen's Avatar
i don't know right now, i am so confused at this point.. and frustrated. After a crap ton of searching it looked like they were basically the same deal, then my struts came in and the bracket is a lot narrower. SO i look around some more and my struts resemble 96-00 more than anything... and what they sent me didn't match what was pictured.... Anyways, i dunno, my car has been sitting for a week now, on top of months, and this is the last thing i need to complete before its done, and i like don't even care at this point. I contacted the re-seller and i'm going to wait and see what they have to say. Right now though, i'm just thinking about shaving a little bit off the bracket.. like tiny amount, and then shaving the bushing down so they fit. its like a 1/4" to narrow, so its not a large difference, but it wouldn't fit normally, and the spring perch is a little different to, resembles the 96-00 more... this is stupid....
Old 04-24-2009, 03:38 PM
Swansen's Avatar
yeah.... so at this point, i think i was sent the wrong struts... After going back over everything i found, (and as it turns out, i always have better luck looking through google images, than the actual web search??) the forks aren't as narrow as what i have... i was given 96-00....
V links V
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%2A%2Apics%2A%2Acivic-wagon-rear-shocks-vs-hatchback-rear-shocks-832089/
http://www.redflagdeals.com/forums/s...d.php?t=723853 (resembles what i have)
http://www.ef-honda.com/ben/EFhybridsus.php(confirms 88-91/92-00 use same rear shock) unless you have https://honda-tech.com/forums/suspension-brakes-54/question-about-88-cr-x-lower-control-aarms-2464744/#post36899274
scdarksol
14
01-15-2021 09:55 AM
krysted9354
01-02-2009 02:52 PM
Azneita
09-21-2005 07:01 PM
TOMSBLUEHONDA23
05-04-2005 07:14 PM
Agent Daimon
06-03-2002 04:29 PM
Quick Reply: 88-91 and 92-95 struts
