h22a starting problems?
have a h22a swapped civic and it will turn over strong but wont crank up? any ideas? distributor or something? what about the main relay? the fuel pump does come on? thanks any help would be great
Team Purple
Re: h22a starting problems?
check basics;
fuel-
air-
spark-
you said the fuel pump comes on, i would check the plugs make sure everythings sparking. if not, work your way back from the plugs to distributor etc....
post back...good luck
fuel-
air-
spark-
ill check the plugs etc for spark when i get home. what about the ecu? everthing looks ok and i couldnt find anything wrong with it? thanks
Team Purple
spnej1
77
02-02-2010 12:03 AM
