EK Ecu plug harness VTEC wiring help
haha so yea. 96 ek hatch, 2000 gsr motor- previous owner was running an obd2a-->obd1 conversion harness with a p06 ecu, i traded the p06 for a 97 gsr ecu. problem is that the wiring coming off the vtec solenoid is tapped into the obd1 conversion harness so im unsure as to where i need to splice in the vtec solenoid wire into the stock obd2a harness to get vtec. searched H-T here for some diagrams and havent been able to find anything, if anyone has a picture diagram that would be awesome or even a detailed description on which plug and what color(s) the wires are for me to splice in to, id really appreciate it. if you need pictures (doubt you will) i can take some.. please help, im VTEC-less
Re: EK Ecu plug harness VTEC wiring help
http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
Do depin get the pins to stay into the ECU plugs use a pair of needle nose pliers to pull up the clip that holds the Pins in.
Unphzd
18
08-24-2010 07:25 PM
