Koni Yellows
Koni Yellows
I just got my set of Koni Yellows for my 2000 Honda Civic EX. How do I tell if they are the correct ones? What number should be on them and where is the number at? I am trying to make sure they gave me the right ones. Thanx
Yeah, all I saw at shox.com was:
012. Koni Sport shocks 1992 - 2000 Set of 4. Koni has free shipping. 565.60
Are Koni's 92-2000 Civics? Or is it split up to 92-95 96-00?
I deffinetly think they gave me the wrong yellows. 2 of them have circles at the bottom where they connect and the other 2 have little stubs at the end.
Re: (Stylinhonda)
Front and back s connect differently. Some sure fire ways to tell if they fit, are to either go try to install them, call Koni, or look at your shocks now.
Re: (Stylinhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stylinhonda »</TD></TR><TR><TD CLASS="quote">I deffinetly think they gave me the wrong yellows. 2 of them have circles at the bottom where they connect and the other 2 have little stubs at the end. </TD></TR></TABLE>
Have you ever installed shocks before? The front two are going to attach to the fork and the rear two are going to have little brackets on the bottom to connect to the rear lower control arm. It "sounds" to me like you got the right ones.
I installed some KYB AGX's a few months ago. I was pretty sure these Konis were the wrong ones. I dont rem what the front look like but i kno the back has 2 things that go on the sides of the lower control arm. There are no little arms on these. So i guess i will have to send them back. thanx for the help.
the rears should look like (w/ springs)
]===|NNNN}
the fronts should look like (w/ springs)
===|NNN}
the fronts should be blunt ends, no forks, because they slide into factory forks
]===|NNNN}
===|NNN}
the soL that could
Suspension & Brakes
02-06-2006 06:27 PM
