Auto-5spd conv. Do i need a lift to remove the tranny?(EK)
im gathering up the parts for a tranny swap, and im wondering if jacking up the car hella high and supportting it with jack stands will do the job. But im not to sure. Would i need a lift to get the tranny out.
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">jesus christ
ht is going down the toilet. </TD></TR></TABLE>
just a question. I don't have access to a lift.
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (sleepyhamsterlx)
i THINK you can support eh tranny with like a skateboard or something and then unbolt it from the car and then jack the car up and pull the tranny from the bottom.
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (viprcr1)
how about you just pick the tranny out of the bay like i did. its not that heavy man, but if it is have a friend push it up from the bottom and you pull it out of the engine bay
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (horror)
Im not to sure how you could pull it from the engine bay unless you plan on taking out engine.
Im doing my tranny either this weekend or next and im just going to put car on jack stands and just put the jack under the tranny cause i could give a **** less if the tranny breaks on its way out cause it wont even move at all.
Can someone tell me if i need to remove my tires when taking the hood off?? Im jsut playing...you can support the weight of the tranny with an old tire or us the jack under the tranny to support and just lift it out of the engine bay. I think it weighs about 30-40lbs. Just make sure you unbolt and unplug EVERYTHING... You dont want to drop it after all this tech advise
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (turbocivic96)
Are you being serious that the tranny only weighs that little. Hope to get mine out this weekend and if I do then id be tempted to put it on a scale to see how much a cvt **** weighs
rotflmfao!!
Anyways... if you have enough room under the car and it's supported high enough on jackstands you can put a floor jack under the tranny just make you you put a piece of wood between them and roll it out. I have a friend just put a clutch in his car and thats what he did. Also heard the you should support the engine with a jack too but he didn't do that and said it only dropped like maybe an inch.
rotflmfao!!
well the weekend finally came and its warm out but i went to look at car and the coilovers look better doing today then the tranny taking out so i got them on and painted my wheels black haha another black ek lowered with black hx's
Solbros Owns Me
Re: Auto-5spd conv. Do i need a lift to remove the tranny?(EK) (tshaw)
just drop it straight down...there's no way you're gonna lift it out of there...no room.
It's not like you're using the tranny again, and auto trannies weigh much more than a manual tranny.
Just unbolt, support the engine, and let the tranny drop
the auto tranny weighs A TONS more than the 5 speed tranny
for some reason i can carry the 5 speed tranny with one arm for a while
the auto tranny i had trouble moving it a couple feetwith two arms
LoW ToNE
12
01-17-2008 07:47 AM
