need help with d16z6 buildup
I have a 94 si with 190000 miles on it. One of my friends recently got a b16 swapped into his 95 ex and he is giving me the motor and tranny. I'm planning on doing a build up of this motor then I'm going to swap it into my car. So far, I know I'm going to get a head package from Exospeed, but I was wondering what I should do for pistons and rods. How much power can the stock rods handle, and are there any oem Honda pistons that will up the compression? I don't really want to have to modify the block at all, so if there arent any Honda pistons that will fit then I guess I'll just have to shell out the extra money for some aftermarket ones.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: need help with d16z6 buildup (ugly_si_hatch)
Don't waste your money going all-motor SOHC.
Turbo it if you want it to be quick/fast, depending on how much you want to spend.
Turbos are always better, HP/$.
Re: need help with d16z6 buildup (boostincoupe)
STR sheet metal Intake manifold and 120 N20 Wet shot is your friend also, I would use P29 Pistons and LS Rods Shot peened, with the head I would go All crower Internals and Crower stage 3 cam then your bolt ons with an agressive Port and plolish and 3 angle valve job on a good CERTi Machine ... Goood amount of HP enuff to whoop up on modded ITR's 2 NAWWZ bottle are recomended Due to the Fact that 120 is fun Get ready to say PEACE OUT to Newer vettes I got a friend who has the almost same build except with JE pistons and Eagle rods with a nurformz Black guard and Romps on B16a powered EG's With bolt ons BAD, Alltogh Bracking tracking at WOT in 4th gear gets annoying
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Don't waste your money going all-motor SOHC.
absolute truth here man. i spent like almost 2 grand on my d16z6, and it dynoed at 115whp. man what a waste of money. now im gonna spend 2 grand on a turbo setup and have at least 180whp
Re: need help with d16z6 buildup (CivicSiRracer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 »</TD></TR><TR><TD CLASS="quote">STR sheet metal Intake manifold and 120 N20 Wet shot is your friend also, I would use P29 Pistons and LS Rods Shot peened, with the head I would go All crower Internals and Crower stage 3 cam then your bolt ons with an agressive Port and plolish and 3 angle valve job on a good CERTi Machine ... Goood amount of HP enuff to whoop up on modded ITR's 2 NAWWZ bottle are recomended Due to the Fact that 120 is fun Get ready to say PEACE OUT to Newer vettes I got a friend who has the almost same build except with JE pistons and Eagle rods with a nurformz Black guard and Romps on B16a powered EG's With bolt ons BAD, Alltogh Bracking tracking at WOT in 4th gear gets annoying </TD></TR></TABLE>
I'm still faster for less, stunna. And more reliable. And getting better gas mileage. And sounding cooler.
http://www.knology.net/~jediklc/D.htm
you can see what compression you will have with various honda parts. i would suggest turboing it as well as far as the cost/hp ratio
Re: need help with d16z6 buildup (lohatch)
Thanks for the help. I kinda wanted to see if I could get my sohc to run some decent times without forced induction but looks like it's really not worth it. I'll probably just pick up a greddy kit and add a front mount and leave it at that.
montanacivic
12-29-2018 04:16 AM
