is it hard to replace shifter?
Re: is it hard to replace shifter? (megotvtec)
helms manual, its very self explanitory when you get the interior out and look under the car...get some of thoose urethane bushing too
very easy all you need to do is pull the shift linkage down on the shifter side and you will see a bolt goint through the bearing at the bottom of the shifter take those out and you can pull it off the linkage after.......for install do that backwards
Re: is it hard to replace shifter? (philly blunt)
It's real self simple , just take your cover off and look at the bolts/nuts.....it's simple mine took about an hour. You dont need directions, it's that easy.
wdskuk
02-13-2004 03:54 PM
