steering wheel tilt in eg--cx???possible?
is it possible to tilt your steering wheel up in a 92 cx without getting the actual parts out of a si??just need to adjust dont need it to be everyday thing
thanks in advance
basically i got a new steering wheel and it goes right across my gauges and **** is gettin frustrating
thanks in advance
Re: steering wheel tilt in eg--cx???possible? (neEven)
Well, to have it adjustable you would need a whole tilt column. The fixed column you have bolts to the underside of the dash, and I suppose you could shim those bolts to get the whole column to come down, and with some longer bolts I would imagine this would be perfectly safe, but I'm not sure your lower trim would still fit.
How far down does the wheel need to go? Any more than a 1/2 inch or sao and I wouldn't reccomend the above method. You could get a used column pretty cheap, and it would be yor best bet.
Josh
Josh
