Rim/Tire Question
Rim/Tire Question
Wel i just put my rota c8's on. they have michillen xgt (i know) tires. I installed them on the front. all the lugs + lock nuts are as tight as i can go.
but when i was driving it after the install, the tires seem to wobble when im going fast. like once in a while? i have no idea what it is.
i went from 175-60-13 tires to 195-60-15. should that make a difference?
Re: (Nader_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D »</TD></TR><TR><TD CLASS="quote">1 - we torqued them
2 - ill go get them balanced once i get the centric rings
If there are no weights on them, thats the problem. Also, ALL Rotas (from what I understand) need the hubcentric rings.
Former Moderator
Re: (kommon_sense)
Honestly Rotas don't absolutely have to have hub centric rings. Some fit perfect, while other are a bit loose in the hub area, but if you torque the wheels properly and make sure the lugs are seated right I don't see why you'd need the rings.
I say you need to have them all balanced.
BTW:
195-60-15 - why such a dumpy-*** tire? Dude that's a stock honda Accord tire size.
Can you not get a 195-50-15 or a 205-50-15?
BTW:
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Can you not get a 195-50-15 or a 205-50-15?</TD></TR></TABLE>
i know man, its just i bought them with those tires and i just just lost my job so i cant spend any cash. and i figured id jsut burn these off and then get some Toyo's in 195-50-15. tires are better than no tires at all!
oh yea, and every time i ask a question you're always there for my answer
MR Dan
03-12-2006 04:06 PM
