Please Read...Need help!
I pulled over cause i thought i heard something rolling around in the trunk...went to check and nothing there...as i got back into the car my knee hit the steering wheel and my car shut off...now it's park along a somewhat busy street asking to be stolen! I took in the battery to auto zone and they said it was still good...checked most of the fuses and they're still all good too!
Funny thing is that my deck does not work nore do any of the lights on the cluster...but the head lights and emergency light work fine...when you try to start it, it's basicly like trying to start the car without stepping on the clutch...it doesn't even crank...Well if you might know what is wrong please help out...thanks!
Re: Please Read...Need help! (2lua)
It soudns to me like you have an ignition cut somewhere. Do you have an alarm installed or even a turbo timer (pretty much anything that taps into your ignition)? If you do then i would check the ignition fuse thats runs from the battery to the fuse box under the dash. If you dont have an alarm then i would start at the fuse box and work my way out. Check ALL the fuses expecially the main ignition fuse and the starter fuse.
Good Luck!
Good Luck!
Re: Please Read...Need help! (lilobusta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic96 »</TD></TR><TR><TD CLASS="quote"> If you do then i would check the ignition fuse thats runs from the battery to the fuse box under the dash</TD></TR></TABLE>
Thanks! You da MAN!
Thanks! You da MAN!
eJDMb16a
10
11-29-2006 07:21 PM
