HELP !!!! Spark won't fire on a ek(b16)
Can anyone help me to solve my problem, my ek b16 won't start cause there aren't any spark. I went got new spark plug, spark plug wire, distributer, and a new ecu.I check all the power wire where it go through to the distributer and still nothing.
Might want to check all of your grounds and make sure there is a good connection and a good grounding surface.
is the motor obd 1 or obd 2.
at ecu are you running
what is the dizzy obd 1 or 2?
Re: (JDMlifestyle)
did u check ur starter relay or the ignition relay?, those are the common problem if u replace all those and it still dont start.
Re: (dahveed)
This is ntensehonda, not redek, but I am having the same problem with my LS, and my question for you is, is the new distrubutor actually new, or used? If it's used, you could still have the same part bad in both distributors, as I am having two bad ignition modules in my car. So , I am having to replace just that part...so, is the dist. new or used?
