95 eg sedan build
95 eg sedan build
First day I got it installed skunk2 springs and tokiko blue shocks the z6 motor has 72k miles on it automatic trans
Re: 95 eg sedan build
Me and a friend pulled the d15 motor out and installed the d16z6 its an automatic for now I have all the parts for the 5 speed swap had to wire up the VTEC solenoid and pressure switch a few threads on here was very helpful on how to wire it properly
Also have the rear disc conversion almost ready to go on I need to press in the es bushings got the 4040 PV and 15/16 integra master going in also
Also recently finished sanding and polishing my gsr blades they were in terrible shape got them off craigslist they were pitted and curbed pretty bad
Hey, you are in Vancouver aren't you?
Just so you know unless you are swapping to bigger front brakes, the 40/40 prop valve would be a wasted effort. And I saw you mentioned the integra 15/16 MC but didn't see you mention the booster. You are aware you will need to swap out the booster as well right?
I like what you've done so far.
Yeah I'm over in Vancouver
And eventually I'm going to upgrade the front breaks so i might as well install the 4040 while I'm in there and is the booster really needed I've read a few threads and they are all different opinions lol
Also have to install my gsr rear lcas and 14mm sway bar so that will be done the same time the rear disc is installed
Also I successfully got my old RTA bushings out today by throwing them in my friends fire place and a couple pieces of wood 45 min later came out clean as a whistle just have to wire wheel them down and paint then I can press in the ES RTA bushings
The bolt pattern is different on the teg master cylinder, so you would need the booster. A 91 ex sedan has a 15/16 master and is same bolt pattern.
Yeah I just masked off the important stuff and sprayed away the trailing arms was painted phantom grey pearl and the dust shield,calipers and hubs all satin black
