Harness connector pn, tps screw size?
Was wondering if anyone had or knew where I could get a new male and female connector for the driver side engine harness to main harness (the big one) for 94 civic, can't seem to find a part number, local dealership isn't much help. I believe another company makes these for Honda, if anyone knows whereabout I can track these down. Don't say junkyard, I've looked.
Also need tps screws for a itr, although all b series probably the same. If anyone knows size/thread pitch.
Thanks
Thanks
Re: Harness connector pn, tps screw size?
16mm x 5mm for tps cant help you with door harness
and the thread I got the info from
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Just an update, that screw size doesn't work (its not a metric screw). Ended up getting 10/32 screws, 5/8 length work fine.
Still trying to locate connectors
