Upcoming 92 hatch build
In the next couple of months I will be building my automatic 92 Civic dx. I've done my research but I can't make up my mind on a couple of things.
I know I want to swap a d-series vtec in for my non-vtec. I was looking at the d15b vtec and the d16z6 in particular.
I know the specs, but I was looking for the opinions on actual performance. I do plan to put a turbo in it, but not in the near future.
I'm going to do a five speed swap with the motor as well. Do I HAVE to buy an auto to manual swap mount, or can I get a manual mount from a junk yard?
Re: Upcoming 92 hatch build
You will need...
brake/clutch pedal assembly
clutch master cylinder/lines
clutch slave cylinder
manual trans/clutch/flywheel/pressure plate
shift linkage/shifter/****
auto-manual trans mount
manual starter
reverse light connector for manual trans
manual passender side trans vibration/torque mount
Thats all I can think of off the top of my head...there may be a couple things im missing (its been a few yrs since I did mine)
That swap is a pita, massively. Do yourself a favor and sell the car and buy one thats already manual
manual starter
Yeah the auto to trans mount can be funny.....
Either cut your current motor mount pocket off reweld in a manual one OR buy the auto to manual CONVERSION mount which allows the car to keep its original passenger side trans mount pocket in place and untouched..
Auto to manual is very simple if you have done one before. first timers will either learn alot from doing so and will be up for another one in the future or some first timers may say to hell with this BS and give up half way through.
I'm going to buy motor and trans as a unit. If I buy another car then I don't know what other expenses to account for. I could just be digging myself in a deeper hole by doing so.
How much power do you think I would gain by building a d15b vtec? While keeping the stock engine bore. Also, would I gain more bottom end by building the head or the block? I want it to be able to pull up the hills of southwest VA, mountainous region, while maintaining a constant speed. Anyone who lives in the mountains will understand. I'm going start out all motor.
talks to himself
If you're worried about being able to climb hills, you should be more worried how much torque the engine has. Torque is a function of displacement and stroke. In which case a D15 isn't great. Do what sleepy recommends and get a H motor. Later on do an HtoB trans swap. Then do a turbo. Reliable power and torque for cheap. And you can phase your build as cash becomes available.
I don't want to do any cutting. I'd rather just drop one in, aside from the tranny swap.
Another thing, I rounded the total for the D15 five speed swap to around $2000. So, say I decided to buy a 5 speed, same model, and put a D15 in it. How much would that set me back, approxomatly? (Preferably a rolling chassis, but beggers can't be choosers.)
Edit: If I can get 200 out of the D15 after it's built I'll be happy.
Master Ninja
If you sticking with a D series motor why not go for a Z6 or Y8?
No one can tell you an exact price on anything. You can find good deals you just gotta search and wait for one to pop up. 2 grand sounds like alot imo.
I don't want to do it cheap, that's why my estimate is steep. Although, if I do end up just getting another car I'll probably go with a B. Then I won't have any down time, and I'll skip the frustrating 5-speed swap. I've always wanted a project car too.
Tons of HP potential, (gobs of torque with high compression/high pressure inducted builds) still very good availability of new and used performance parts, very good availability of interchangeable "used" salvage yard parts, ease of basic drop-in configuration, help with every possible aspect of building and modification and troubleshooting and tuning - doing a B-Series makes the most economic, fewest headache, least time required sense. If you have money, do the K-Series.
The B-series should give me what I'm looking for, and then some.
If I boost in the future what kind of compression ratio should I go for?
You should stop and read the FAQ's, both here as well as in the forced induction section. CR is less important than how competent your tuner is. Any dumbass with a laptop can tune for boost on 8:1 CR - it takes a real pro to tune boost on 11:1.
If that's correct, I'd just get the basic swap into it first, enjoy it, acquire the hands-on platform knowledge you'll get in the swap process. Then, while you're reading up on the B-Series turbo build threads (there are a lot of good ones here) start listing/buying the upgrade parts for your induction goals at that point. There are some performance parts that can be used in both applications like ignition upgrades, ECU upgrade, cam gears, upgraded oil, water and fuel pumps, etc. that I'd get first once the commitment goal is defined and the finances are solidified.
I'm somewhat biased. Safety, Safety, Safety! The initial areas that I'd focus on for a high hp ride, believe it or not, are brakes, suspension, steering and then high HP power.
Last edited by peaceable; 06-16-2013 at 02:52 PM. Reason: Added another system part catagory
From my perspective, it depends on what you're going to use it for. I'm assuming a DD? There's a lot of variables.
I agree on the safety part. I would much rather have a good handling car than a death trap. Rear disc conversions and a suspension kit are already on my list.
When it comes to tuning the turbo, I don't plan on doing that myself. I'll probably have it profesionally tuned so I don't muck things up.
I'll probably buy a new car so I don't have any down time on my DD. I have to have a ride to be able to fund the build.
When it comes to tuning the turbo, I don't plan on doing that myself. I'll probably have it professionally tuned so I don't muck things up.
Persistence in vision at one step at a time.
Markis.
01-05-2005 10:33 AM
wannab20hatch
08-21-2002 07:03 PM
