Need help car not starting!
I have a 92 civic hatch with a b18b1 swap. I just put a b18a1 head on due to valve lash issue with the old. I put everything back together and im only getting spark in cylinder number 1 . Changed the dizzy and ecu and time is good and same problem. Any suggestions?
The Grumpiest
Re: Need help car not starting!
There is. It's in the "Frequently Asked Questions" sticky that none of you new people bother to read. I wonder how an '11 missed it?
OP. Are you sure everything is timed correctly? Ignition and mechanical? How did you verify that only one cylinder is firing? Double check your work?
But its just... so.... hard
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Just so you know OP, I now have Carpal Tunnel from finding that link
Khmi
07-08-2007 04:52 PM
egriffith45
08-19-2006 08:56 PM
Punisher
22
09-04-2002 07:28 PM
